Stránka 13 z 16
Re: Nová koncepce silniční sítě + dopravní značení
Napsal: 13.10.2021 19:28:04
od Rio13zm
Brutus píše:Škoda, že sa sem nedá pripojiť pdf súbor. Dal by som sem výrobné výkresy na D1 a D2 v Bratislave.
tu je tebou spominane a mnou spracovane pdf-ko k nahliadnutiu pre ceskych kolegovcov
https://dialnice.info/gallery/image.php ... e_id=47311
https://dialnice.info/gallery/image.php ... e_id=47312
https://dialnice.info/gallery/image.php ... e_id=47313
https://dialnice.info/gallery/image.php ... e_id=47314
https://dialnice.info/gallery/image.php ... e_id=47315
https://dialnice.info/gallery/image.php ... e_id=47316
https://dialnice.info/gallery/image.php ... e_id=47317
https://dialnice.info/gallery/image.php ... e_id=47318
https://dialnice.info/gallery/image.php ... e_id=47319
https://dialnice.info/gallery/image.php ... e_id=47320
https://dialnice.info/gallery/image.php ... e_id=47321
https://dialnice.info/gallery/image.php ... e_id=47322
https://dialnice.info/gallery/image.php ... e_id=47323
https://dialnice.info/gallery/image.php ... e_id=47324
https://dialnice.info/gallery/image.php ... e_id=47325
https://dialnice.info/gallery/image.php ... e_id=47326
https://dialnice.info/gallery/image.php ... e_id=47327
https://dialnice.info/gallery/image.php ... e_id=47328
https://dialnice.info/gallery/image.php ... e_id=47329
https://dialnice.info/gallery/image.php ... e_id=47330
https://dialnice.info/gallery/image.php ... e_id=47331
https://dialnice.info/gallery/image.php ... e_id=47332
https://dialnice.info/gallery/image.php ... e_id=47333
https://dialnice.info/gallery/image.php ... e_id=47334
https://dialnice.info/gallery/image.php ... e_id=47335
https://dialnice.info/gallery/image.php ... e_id=47336
https://dialnice.info/gallery/image.php ... e_id=47337
https://dialnice.info/gallery/image.php ... e_id=47338
https://dialnice.info/gallery/image.php ... e_id=47339
https://dialnice.info/gallery/image.php ... e_id=47340
https://dialnice.info/gallery/image.php ... e_id=47341
https://dialnice.info/gallery/image.php ... e_id=47342
https://dialnice.info/gallery/image.php ... e_id=47343
https://dialnice.info/gallery/image.php ... e_id=47344
https://dialnice.info/gallery/image.php ... e_id=47345
Napsal: 14.10.2021 21:58:30
od Rio13zm
Napsal: 15.10.2021 6:13:13
Německo...
Napsal: 15.10.2021 7:17:15
Je jedno, od koho se který stát inspiruje. Estonsko podle Skandinávie, Albánie podle Itálie :-) Hlavní je přehlednost. Pro mě nádherně dle evropské úmluvy sjednocená navigace. Na návěsti se dá už z dálky poznat jak se budu řadit v odbočovacích pruzích, aniž by tu musela stát další značka IP19 jako u nás. A směrníky jsou umístěné přímo v křižovatce před odbočením, přesně tak jak to má být. Česko je ostuda, hlavně v nejednotnosti správ a v nedodržování předpisu.
Napsal: 17.10.2021 20:54:23
od Rio13zm
od 1.10. sa zavadza sekvencne cislovanie vyjazdov, rusi sa kilometricke.
Napsal: 18.10.2021 8:56:48
od Martin96
Nemám rád sekvenční číslování výjezdů, asi jsem zvyklý z Čech, ale celkově, když vidím v navigaci číslo sjezdu v km, tak jen sleduji, na jakém jsem km a podle toho vím, jak dlouho ještě po dálnici pojedu. Nehledě na to, že když dodatečně přibudou MÚK a k tomu se složitě připisují různá písmenka jako v Německu... Obzvlášť ještě, když vzdálenosti mezi exity se kolikrát liší, a na Slovensku víc než u nás (od 4 až po 24 km).
Snad jedině, kdyby se v tomhle Slováci inspirovali v Polsku a na návěst za exitem uváděli název příštího exitu vč. čísla se vzdáleností v kilometrech.
Všiml jsem si značení silnice 127 - jak to vypadá z přečíslováním silnic I. a II. tříd? Silnice III. třídy už jsou hotové, s tím problém nemám, naopak jsem rád, že zmizely kolikrát i šesticiferná označení, plus ještě jsou všude silnice značeny, ne jako u nás maximálně na mostech, přejezdech či propustcích...
Napsal: 18.10.2021 12:48:57
Rio13zm píše:od 1.10. sa zavadza sekvencne cislovanie vyjazdov, rusi sa kilometricke.
Doporučuji z těch zemí A, D, kopírovat pouze to dobré, ne vše.
Napsal: 18.10.2021 21:49:40
od Rio13zm
Ved prave a toto je ta dobra vec :)
(A) maju kilometricke cislovanie.
Mne osobne je uplne u riti, ci exity su sekvencne alebo kilometricke, ale skor ci su pomenovane, alebo nie. Casto chodim zo Zlatych Moraviec do Bratislavy s dcerou do nemocnice na Kramare a vobec si nepamatam cislo exitu ale meno vyjazdu Mlynska Dolina si pamatam. Tak isto by som vedel vymenovat skoro vsetky vyjazdy na tejto trase, ale cisla exitov nie, maximalne ten moj, R1 70km Zlate Moravce, +/- este niekolko dalsich.
Hlavne nech je poriadne znacenie, pred cestou si pozriem v mape, kde idem a to mi staci.
Urcite si nepocitam kilometre, to su take nepodstatne informacie, lebo staci 5 minut jazdy a tie kilometre v kuse ubiehaju.
Napsal: 18.10.2021 22:08:11
od Rio13zm
Martin96 píše:Nehledě na to, že když dodatečně přibudou MÚK a k tomu se složitě připisují různá písmenka jako v Německu...
Rozne pismenka nie, iba A a B, urcite nie cela abeceda. Tomuto sa budeme snazit zabranit asi tak, ze cisla buducich vyjazdov sa rezervuju uz teraz a ani nove vyjazdy nevznikaju kazdy rok.
Martin96 píše:Všiml jsem si značení silnice 127 - jak to vypadá z přečíslováním silnic I. a II. tříd? Silnice III. třídy už jsou hotové, s tím problém nemám, naopak jsem rád, že zmizely kolikrát i šesticiferná označení, plus ještě jsou všude silnice značeny, ne jako u nás maximálně na mostech, přejezdech či propustcích...
Pytal som sa na to a aktualne nie je politicka vola. Ked to aktualne bude, urcite to sem napisem ;)
Na zaciatku tohto vlakna som daval koncept na precislovanie D/R a cesty 1,2,3tr., spravili sa iba tie Trojky.
Za poslednych par rokov sa ale spravil kus roboty, pismo Tern, nova vyhlaska, nove znacky a znacenie VL, teraz toto sekvecne cislovanie. Mozno casom aj to precislovanie bude.
Napsal: 18.10.2021 22:35:21
Nevím jak to máte na Slovensku, ale v ČR v rádiu je naprosto běžné, že se o kolonách a omezeních informuje podle staničení - tzn. když je kolona na D1 167. km, tak bezpečně vím, že je to z Prahy až za Jihlavou... kdyby se řeklo "u Velkého Beranova", tak nebudu vědět, protože to je pro mě nevýznamná víska a nevím kde leží. Kdyby se řeklo sekvenčně u exitu 15, tak taky nevím, jestli to je před nebo za Jihlavou a tedy jestli se tím mám stresovat. Prostě kilometrické označování má výhodu v tom, že jakmile si tu svou trasu "najedete", tak budete mít mnohem lepší odhad na lokalizaci sjezdů, uzavírek, nehod.
Napsal: 19.10.2021 11:11:44
A mě zase neřekne nic kilometr a ani číslo exitu. Pamatuji si jen jako ostatní, že Brno je cca 200 km od Prahy, takže podle staničení jen poznám jak je to asi daleko před nebo za Brnem :-) Ale Beranov vím zase hned :-)
Napsal: 19.10.2021 11:48:50
To mě zase vyhovuje značení exitů podle km a ne pořadí. Pokud jedu někam kde to neznám prostě si pamatuju sjet na exitu 78 a vím jak je to ještě daleko a pokud je nějaké hlášení tak vím jestli se mě to ještě týká a nebo už ne.
Napsal: 26.11.2021 23:44:01
Informačné dopravné značky môžu byť aj v jazyku menšiny, prezidentka podpísala novelu :arrow:
https://www.webnoviny.sk/nasadoprava/in ... la-novelu/
Obce dostanú možnosť použiť na navádzanie účastníkov cestnej premávky informačné dopravné značky s názvami vyznačených cieľov v štátnom jazyku aj v jazyku menšiny.
Napsal: 13.12.2021 13:45:56
LÍNIOVÉ RIADENIE DOPRAVY ÚSPEŠNE SPUSTENÉ AJ V ĎALŠEJ FÁZE
zdroj: portál NDS
zdroj: portál NDS
štvrtok, 9. december 2021
Najmodernejšie líniové riadenie cestnej premávky je už spustené v plnej verzii – kompletne na úsekoch bratislavských diaľnic D1 a D2 od štvrtkového rána (9.12.2021).
NDS v nočných hodinách pristúpila k spúšťaniu líniového riadenia dopravy aj na úseku D2 od križovatky Jarovce po Mlynskú dolinu v oboch smeroch. V prvej etape sme dopravu líniovo riadili len v trase D1 medzi križovatkou Bratislava, Pečňa a Bratislava, východ. Zavedením systému inteligentných, chytrých diaľnic dokážeme navýšiť kapacitu preťažených úsekov o 10 až 20% oproti stavu bez aktívneho riadenia. Na území Bratislavy výrazne znížime výskyt kolón a ich rozsah, zlepšíme plynulosť dopravy a zároveň včasným varovaním vodičov pri dopravných incidentoch zvýšime bezpečnosť cestnej premávky. V časoch priaznivých dopravných a poveternostných podmienok bude možné jazdiť rýchlosťou 130 km/h. Medzi 22:00 a 06:00 bude po novom rýchlosť obmedzená na 100 km/h.
Optimalizovať dopravu nám pomáhajú desiatky senzorov
Vstupné údaje pre riadiaci systém zbierame zo 178 senzorov umiestnených na diaľnici. Ide najmä o detektory vozidiel, stavu vozovky a senzory ovzdušia (teplota, zrážky, dohľadnosť). Systém získané údaje overí, vyhodnotí, následne namodeluje premávkové procesy a vytvorí krátkodobé predikcie ďalšieho vývoja. Riadenie premenných dopravných značiek bude prebiehať automaticky, pričom ich nastavenie bude prehodnocované každých 60 sekúnd, pri závažnejších incidentoch aj skôr.
https://ndsas.sk/press/press-narodna-di ... alsej-faze
Napsal: 13.4.2022 13:08:05
Slovensko sa pripravuje na inteligentnú dopravu, výskumníci skontrolujú značenie :arrow:
https://www.webnoviny.sk/nasadoprava/sl ... -znacenie/
Napsal: 23.4.2022 20:13:48
Diaľničiari plánujú minúť na vodorovné značenie milióny eur, súťaž brzdia námietky
https://www.webnoviny.sk/nasadoprava/di ... -namietky/
NDS neumí vytendrovat ani barvy :lol: :evil: Přitom na tohle není důvod to outsourcovat. Tuto činnost by bez problémů zvládlo každé SSÚD. Tolik totiž ta technika ani barvy nestojí. Jsou samosprávní kraje, které mají ve vlastní režii tuto činnost. Právě pro tento fakt, že to je levnější. Lze samozřejmě svěřit údržbu i soukromé společnosti, ale dělá se to pak spíš s veškerou údržbou a ne že explicitně jde oprava vozovek, extra značení atd. a NDS dělá základní údržbu na košení nebo zimní údržbu. Tento kombinovaný systém je drahý s nižším efektem. Když vezmeme v potaz náklady na každé středisko údržby ...
Napsal: 4.12.2022 0:12:20
od Rio13zm
Dávno som nič nenapísal, aspoň jeden krátky príspevok.
Na stránke http://ocestnejpremavke.sk/ sú tri články, ako by sa malo postupne meniť staré značenie za nové.
Ktoré značky sa zmenia len dizajnovo, ktoré sú vymenené úplne a ktoré zrušené.
http://ocestnejpremavke.sk/ako-vymenit- ... za-nove-i/
http://ocestnejpremavke.sk/ako-vymenit- ... a-nove-ii/
http://ocestnejpremavke.sk/ako-vymenit- ... -nove-iii/
Napsal: 4.12.2022 7:37:05
To je zajímavá stránka. Umístnil jsem odkaz do úvodního příspěvku.
Napsal: 4.12.2022 19:52:24
No, ten zákaz motocyklů je podle mě příšerná značka :-) Nejdřív jsem myslel, že je to dalekohled. A v kombinaci pro zákaz motorových vozidel...
Také značka pro zákaz vjezdu s přívěsným vozíkem mi připadala logičtější, protože nyní to vypadá jako jen zákaz velkých nákladních přívěsů.
Jinak se mi ta příručka moc líbí a co bych od Slováků kromě jiného převzal je jasné rozeznání, jestli je to část obce (305) nebo obec. U nás to je příšerně nejednotné v mnoha variantách okresní či lidové tvořivosti.
Napsal: 9.12.2022 9:42:35
BRATISLAVSKÉ DIAĽNICE DOSTÁVAJÚ NOVÉ DOPRAVNÉ ZNAČKY
piatok, 9. december 2022
zdroj: portál NDS
zdroj: portál NDS
Napsal: 20.1.2023 19:39:12
od Rio13zm
Dnes sa schválili nové a upravené Vzorové listy 6.1, 6.2, 6.3, 6.4 a Technické predpisy 117 a 118 k značeniu.
Napsal: 9.2.2023 12:37:28
Nová dopravná značka na križovatke – „zelená šípka“
zelená šipka, která nezhasne
https://podkapotou.zoznam.sk/cl/1005027 ... a-nezhasne
https://transport.sk/spravy/cestna-dopr ... rizovatke/
Napsal: 9.2.2023 13:36:02
Gratulace :)
Napsal: 9.2.2023 14:45:18
od darwousek
Taky se přidávám ke gratulaci. Snad se to brzy dostane i do ČR . Někde by se to fakt hodilo .
Napsal: 9.2.2023 19:28:14
U nás pevná šipka bývala, ale tuším novelou v 80. letech zmizela.
