Texas
Re: Texas
Jižně pod Dallasem se nachází asi 25 tis. městečko Corsicana. Dne 21.10. se zde otevřel 19 km dlouhý obchvat v rámci tahu SH 31. Obchvat obchází město po jižním reliéfu.
https://twitter.com/i/web/status/1451186729902231563
Re: Texas
TxDOT ready to begin construction on Loop 88
TxDOT is making history this week, as the state begins work to transform FM 1585 into Lubbock’s second major state loop, Loop 88. Contractor Sacyr Construction USA, LLC, of Miami, Florida, began placing work zone signs along the Phase 3A and 3B Loop 88 project limits and prepping the work zone last week. Work is scheduled to begin on Nov. 8.
Phase 3A project limits are from Avenue U to Memphis Avenue, and 3B includes the area from Memphis to Chicago Avenue. Total cost for both phases is $154.8 million.
Phases 3A and 3B are the first of seven phases (incorporated into 5 projects) to build a freeway facility, along Segment 3 of the Loop 88 corridor. Segment 3 spans from US 87 to US 62/82 in Wolfforth. Phase 3C, which includes the US 87 interchange, is the next project scheduled to begin construction in 2026.
Construction on Phase 3A and 3B is estimated to take up to five years to complete.
https://www.txdot.gov/inside-txdot/medi ... -2021.html
Re: Texas
Ship Canal Bridge project in Texas restarting
Construction work is now restarting on the Houston Ship Canal Bridge in Texas. The bridge has been the subject of considerable controversy after construction was halted on the project over safety concerns.
The approval has been given for the work to restart, however the project is now likely to cost up to US$300 more than what had been planned originally. Construction on the bridge was halted due to concerns over the safety of the design. Changing the design means removing some of the base structures that have already been erected, accounting for around $50 million of the extra $300 million now needed to build the bridge.
The replacement of the 40 year old road bridge with a new bridge forms part of a wider project to widen the tolled route on either side of the Houston Ship Canal. The work is now expected to cost in excess of $1.3 billion.
Harris County Commissioners Court has approved the plans for the new and more conventional design for the bridge. The work will take an additional three years to complete now that approval for the revised design has been given.
The construction team will have to remove the base structures for the supports that would have held up the bridge. The original design called for the use of precast concrete in segments, however the bridge will now be built of steel instead.
The new design will have 157m high towers and will have two separate spans, each carrying four lanes of traffic. The first span is expected to open in 2025, with the second span opening in 2027. Once the second span is complete, demolition work will be carried out on the existing bridge, which dates from the early 1980s. The new bridge will improve journey times for drivers in the Houston area.
Re: Texas
Dne 9.3. se do provozu odevzdala 1. etapa Montana Avenuje (US 62/180) v El Paso. Jde o upgrade na dálniční parametry. Úsek měří 5 km a je mezi Global Reach Drive a Saul Kleinfeld Drive ve východní části El Paso.
poloha na mapě: https://www.openstreetmap.org/?mlat=31. ... /-106.3118
https://eu.elpasotimes.com/story/news/t ... 426534002/
Re: Texas
Texas Department of Transportation (TxDOT) v polovině 2021 vyhlásil tendr na Phase 2 for the Interstate 35E (I-35E) od Interstate 635 v Dallas po Denton County v Carrollton.
Postaví to Fluor Corporation a Austin Bridge & Road. A to za 640 mil. USD. Stavební práce se začnou v polovině 2022.
Úsek měří asi 10 km. Kontrakt obnáší projekt, stavební část, plnou rekonstrukci a rozšíření ze 6- na 8- pruh. Dále se přistaví nové připojovací a odpojovací pruhy.
Stavební práce se mají dokončit v roce 2026.
Re: Texas
TxDOT breaks ground on 5-year, $1.5B I-35 construction project
Construction has started on the first stage of the I-35 elevated express lanes in northeast San Antonio. This is a $ 1.6 billion project and includes 10 miles of two elevated express lanes in each direction.
https://www.mysanantonio.com/news/local ... 165450.php
Celý projekt zahrnuje 3 fázy a 32 km, zde jsou informace: https://www.texashighwayman.com/i35nex.shtml
Re: Texas
Dne 19.5. se do provozu dostávají úseky H a I-1 v rámci SH 99, Grand Parkway, ve městě Houston. Nová část dálnice měří asi 60 km a jde od I-69 u New Caney po I-10 u Mont Belvieu. Kompletizuje se tak východní část okruhu města.
SH 99 je 3. okruh (beltway) kolem města Houston. Specifikum této sekce je, že je vedená ve vesnickém prostředí, takže větší část má jen 2 jízdní pruhy, ale všechny nájezdy jsou uzpůsobené dálničnímu parametru.
https://www.houstonchronicle.com/news/h ... o-22492703
Re: Texas
sledovaný projekt v tématu
výstavba nového mostu Harbor Bridge v Corpus Christi; web: https://harborbridgeproject.com/
posledně asi před rokem: http://forum.ceskedalnice.cz/viewtopic. ... 48#p236548
K 2.9. vyšel článek:
Flatiron Dragados JV souhlasil s tím, že vyhoví požadavku texaského ministerstva dopravy (TxDOT) na vyřešení konstrukčních nedostatků v přístavním mostě Corpus Christi v hodnotě 930 milionů dolarů, čímž se vyhne odstranění z projektu.
https://www.newcivilengineer.com/latest ... 022/?tkn=1
TxDOT pozastavil stavbu mostu v červenci poté, co zpráva od nezávislého konzultanta Systra International Bridge Technologies (IBT) upozornila na množství konstrukčních problémů, které nesplňovaly normy kódu a ohrožovaly bezpečnost konstrukce. Flatiron Dragados a projektanti Arup-Carlos Fernandez Casado vyvrátili, že by tam byly nějaké problémy, a odmítli změnit plán.
Re: Texas
:arrow: Dnes 28.10. byl slavnostně otevřen úsek 5,6 mil (9 km) přestavby dálnice USA 77 na I-69E v jižním Texasu. To je severně od Raymondville, na Willacy / Kenedy County Line.
Kenedy County je známý tím, že je jedním z nejméně zalidněných okresů ve Spojených státech, má 350 obyvatel, ale rozkládá se na ploše 5 000 km² / 1 950 čtverečních mil. US 77 prochází krajem, většina zbývajících prací na modernizaci US 77 na I-69E je v tomto kraji. US 77 je již čtyřproudá rozdělená dálnice přes Kenedy County.
https://twitter.com/i/web/status/1586050178875887618
:arrow: Prodloužení Texas State Highway 249 o délce 10 mil / 16 kilometrů se otevírá tento víkend (může to být i dnes) severozápadně od Houstonu. Jedná se o "Aggie Expressway". Na rozdíl od části Montgomery County není tato část Texasu 249 zpoplatněna.
Design tohoto projektu byl několikrát změněn. Je to součást projektu propojení Houstonu s College Station (Aggie je přezdívka pro Texas A&M University v College Station). Většina Texasu 249 je zařízení typu dálnice (většinou zpoplatněné), ale to je tak daleko do venkovských oblastí v Grimes County, že se rozhodli pro rychlostní silnici. Plánuje se však, že se nakonec stane dálnicí se čtyřmi jízdními pruhy.
Texas 249 má v této oblasti poměrně velký počet mostů z odvodňovacích a ekologických důvodů. Existuje 13 mostů, které zřejmě mají takovou funkci, kromě mostů vedoucích přes silnice a železnice.
poloha na mapě: https://i.imgur.com/IFGRYzD.png
Re: Texas
Texas Started 1,217 Transportation Projects in Year-One of Infrastructure Law, New Report Shows
WASHINGTON, Nov. 18, 2022 /PRNewswire/ -- Texas leveraged $5.2 billion in federal highway and bridge formula funds in FY 2022 to help jumpstart 1,217 new improvement projects in communities across the state during the first year of the Infrastructure Investment and Jobs Act (IIJA), a review of U.S. Treasury Department data through September 30 shows.
Nationally, over 29,000 IIJA projects were launched through the end of September. The five largest projects supported by formula funds in Texas are:
Expanding Loop 1604 on I-10 in San Antonio - $365.7 million
635 East Project in Dallas - $225.0 million
I-35 Widening in Travis County - $218.6 million
Irving Interchange Project in Dallas - $171.5 million
Widen Loop 375 in El Paso - $95.4 million
https://www.prnewswire.com/news-release ... 82916.html
Re: Texas
Ještě bych dal do pozornosti amatérský web fanouška dálnic TX: https://www.texashighwayman.com/index.shtml . Tento odkaz jsem zapracoval do úvodu.
No, abych se vrátil k tomu výše uvedenému příspěvku. Tak tedy TX si taky polepšil v letošním roce z federální vlády o 5 mld. USD vzhledem na jeho velikost, rozsah dálnic a mostů. Hned ten největší projekt dostal taky velkou porci peněz proti ostatním státům, tak bych ho opsal:
Expanding Loop 1604 on I-10 in San Antonio aneb Loop 1604 from SH 16 to I-35
https://www.txdot.gov/content/txdotreim ... 6-i35.html
Bexar County, je právě San Antonio. Co je to Loop, tak je to v principu okruh.
https://www.austintexas.gov/I-35Mobility
https://www.txdot.gov/content/txdotreim ... hange.html
Re: Texas
Před týdnem se konalo slavnostní zahájení stavby Corrigan Relief Route v Texasu. Je součástí budoucí I-69. Je to 10 km dálnice. Investice činí 173 mil. USD.
lokalita na mapě: https://www.google.com/maps/@30.99556,- ... a=!3m1!1e3
https://twitter.com/i/web/status/1599873778808414215
Re: Texas
The Engineering News Record (ENR) uvádí, že stavba nového hlavního mostu Corpus Christi Harbour Bridge v Texasu byla obnovena 15. prosince. Bude to největší lanový most zcela ve Spojených státech.
foto: https://i.imgur.com/sL2Ie40.jpg
Jak již bylo zmíněno dříve, tento most měl velké konstrukční chyby, které mohly za určitých okolností vést ke zřícení mostu. Projektování hlavního mostu bylo zastaveno v listopadu 2019, stavba na celém mostě byla zastavena v červenci 2022. Mezi projektantem a TxDOT došlo k řadě sporů.
Dokončení mostu se nyní předpokládá v polovině roku 2025. Většina hlavního mostu musí být ještě postavena, ale tento most má velmi velká nájezdová rozpětí, která jsou většinou dokončena.
https://www.enr.com/gdpr-policy?url=htt ... -to-resume
Re: Texas
FHWA and TXDOT Sign Agreement to Allow I-45 North Houston Highway Improvement Project to Move Forward
Today, the Federal Highway Administration (FHWA) and the Texas Department of Transportation (TxDOT) signed a Voluntary Resolution Agreement (VRA) resolving the FHWA Title VI investigation of the I-45 North Houston Highway Improvement Project (NHHIP) and lifting FHWA’s pause on the project.
The $9 billion NHHIP will ultimately reconstruct I-45 North between Houston's downtown and the North Sam Houston Tollway to bring the roadway up to federal safety standards and enhance mobility. Improvements also include increased modal options through four non-tolled managed lanes, bicycle and pedestrian features along frontage roads and cross streets, and trails parallel to bayous within the right of way. Detention ponds, pump stations and other flood mitigation tools are also included in the project. Air quality will also benefit from less congested traffic and idling cars along with various project mitigations.
“This portion of I-45 was built in stages in the 1950s and 1960s and the design remained essentially the same while the area population has doubled,” stated Marc Williams, TxDOT executive director. “The reconstruction of I-45 will address mobility needs for people and freight, while also improving safety and a number of environmental mitigations that include critical measures to improve storm water drainage. Considering the recently executed agreements with Houston Mayor Sylvester Turner, Harris County, and now the FHWA, we are excited to get this critical infrastructure project moving with our partnering agencies.”
https://highways.dot.gov/newsroom/fhwa- ... oject-move
  • S 9 miliardami dolarů jde o jeden z největších, ne-li největší aktuální dálniční projekt ve Spojených státech.
    Celý projekt již má environmentální schválení, s návrhem EIS v roce 2017 a konečným EIS v roce 2020. Bidenova administrativa však projekt pozastavila, aby provedla šetření. Tato pauza je nyní zrušena a megaprojekt může pokračovat.
    To značí demolici I-45 na západní straně Downtown Houston (Pierce Elevated) a spojilo I-45 a I-69 podél východní strany Downtown Houston. Projekt by rekonstruoval několik dálnic na dálniční křižovatky. Kromě toho bude I-45 rozšířena z 9 na 12 pruhů z I-10 na Beltway 8. V současné době se jedná o jeden oboustranný pruh se 4 pruhy pro všeobecné použití v každém směru. Oboustranný pruh bude nahrazen expresními pruhy 2x2, podobně jako u Katy řízených pruhů. To by také nahradilo zastaralou I-610 výměnu.
Re: Texas
:arrow: Zdá se, že hlavní jízdní pruhy I-69 byly otevřeny 25. února 2023 mezi Midline a Clevelandem v Texasu. Toto je přibližně 4 míle / 6 km přeměna dálnice z US 59 na I-69, nedaleko severovýchodně od Houstonu. I-69 má šest jízdních pruhů.
https://twitter.com/i/web/status/1629151727218790404
:arrow: První přímé konektory přestupního uzlu I-30 / SH 360 v Arlingtonu v Texasu jsou konečně otevřeny do provozu, 7 let po zahájení stavby. Doufají, že do konce roku dosáhnou podstatného dokončení. Toto může být nejpomalejší silniční projekt v celém Texasu.
https://www.dallasnews.com/news/transpo ... k-be-done/
I-30 původně otevřen jako Dallas-Fort Worth Turnpike v roce 1957, na tomto místě byla původně postavena výměna trubek s mýtnou budkou. Zatímco mýtné bylo zrušeno v roce 1976, pořádná dálnice k dálniční křižovatce není postavena až do současnosti. Výměna mezi oběma dálnicemi vyžadovala průchod semaforem na předních komunikacích.
Arlington má téměř 400 000 obyvatel a je největším předměstím Texasu a jedním z největších v USA.
Re: Texas
Byly zahájeny stavební práce na projektu Interstate 35 Capital Express North v Austinu v Texasu. Projekt řídí Texaské ministerstvo dopravy (TxDOT) a jeho realizace by měla trvat pět let. Cílem projektu je zvýšit plynulost dopravy a snížit kongesce.
Projekt stojí 606 milionů USD a pomůže snížit dopravní zácpy. Tato část prochází centrem Austinu. V oblasti v současnosti dochází k pravidelným dopravním zdržením pro řidiče. Práce zahrnují nový jízdní pruh pro vozidla s vysokou obsazeností v každém směru podél I-35 z SH 45 North na US 290 East, stejně jako práce na modernizaci šesti mostů na trase. Křižovatky budou také vylepšeny, včetně rozbíhající se diamantové křižovatky na Wells Branch Parkway. Kromě toho budou vybudovány pěší a cyklistické stezky a dojde k dalšímu zlepšení bezpečnosti a mobility v rámci limitů projektu.
Re: Texas
Práce na modernizaci 8,5 km dlouhého úseku zpoplatněné silnice probíhají severně od Austinu v Texasu. Zlepšení zpoplatněné silnice 183A zahrnuje vybudování dvou dalších pruhů v obou směrech. Projekt v hodnotě 259 milionů USD je v současnosti dokončen z přibližně 55 % a má být dokončen v roce 2025.
Projekt je určen ke snížení kongescí na úseku trasy mezi Leander a Liberty Hill a je řízen Central Texas Regional Mobility Authority. Jedním z nejnáročnějších aspektů projektu je tunelování pod dálnicí 29. Práce na zlepšení budou zahrnovat zařízení pro zranitelné účastníky silničního provozu.
Projekt je jedním z několika ve městě Austin a jeho okolí, které zažívá růst populace a musí rozvíjet svou dopravní infrastrukturu, aby se s tím vyrovnalo.
Dalším velkým projektem je práce na Interstate 35 Capital Express North za 606 milionů dolarů. To je řízeno texaským ministerstvem dopravy (TxDOT) a jeho provedení by mělo trvat pět let. Cílem projektu je zvýšit plynulost dopravy a snížit kongesce.
Silnice prochází centrem Austinu a v současné době zažívá pro řidiče pravidelná dopravní zpoždění. Práce zahrnují nový jízdní pruh pro vozidla s vysokou obsazeností v každém směru podél I-35 z SH 45 North na US 290 East, stejně jako modernizaci šesti mostů podél trasy.
Re: Texas
Dne 19.5. se do provozu uvedl 7 km úsek dálnice USA 281 severně od San Antonia. Jde o prodloužení dálnice typu freeway č. 281 z dálnice Stone Oak Parkway k linii Comal County.
https://www.texashighwayman.com/us281exp.shtml#phase2
Re: Texas
Ferrovial slaví otevření NTE 35W segmentu 3C v Texasu
AUSTIN, Texas, 20. června 2023 /PRNewswire/
Společnost Ferrovial, světový lídr v oblasti infrastrukturních řešení, dnes oznámila dokončení třetího segmentu projektu North Tarrant Express (NTE) 35W ve Fort Worth v Texasu.
Tento úsek I-35W o délce 10,8 km od N. Tarrant Parkway k Eagle Parkway ve Fort Worth, představující investici více než 1 miliardu USD, sestává z vylepšení s rekonstrukcí hlavních jízdních pruhů, rozšířeími a přidáním TEXpress Lanes.
Koncese vedená dceřinou společností Ferrovial Cintra financovala a navrhla nový dálniční systém a bude provozovat a udržovat tento segment podél I-35W jménem Texas Department of Transportation (TxDOT). Kromě společnosti Cintra, která je většinovým vlastníkem (53,7 %), patří mezi akciové partnery společnosti Meridiam (17,5 %) a APG (28,8 %). Silnice byla dokončena tři měsíce před plánovaným termínem a byla postavena společnostmi Ferrovial Construction a Webber, rovněž dceřinými společnostmi Ferrovial.
https://www.prnewswire.com/news-release ... 55576.html
Fort Worth stále roste velmi rychle, mohl by překonat Dallas jako největší město v Metroplexu, protože Dallasu chybí prostor k růstu. Fort Worth má nyní 958 000 obyvatel, okres Tarrant má nyní 2 111 000 obyvatel, což je nárůst z 1,4 milionu v roce 2000. Byly vynaloženy značné investice do přizpůsobení se tomuto velkému populačnímu růstu, přičemž „North Tarrant Express“ je sítí placených expresních pruhů v regionu.
Re: Texas
psáno v 12/2022:
Diaľničiar píše: 18.12.2022 22:42:14 sledovaný projekt v tématu
Stavba masivního nového Harbour Bridge byla dvakrát zastavena.
video viděl již skoro 1 mil. lidí:
Re: Texas
Společný podnik nazvaný Lone Star Constructors bude řešit další kontrakt na trasu I-35 v Texasu. Fluor vede společný podnik, jehož součástí je také Austin Bridge & Road. Balíček prací v hodnotě 700 milionů USD bude proveden podle modelu návrhu, výstavby a údržby kapitálu.
Texaské ministerstvo dopravy (TxDOT) udělilo projekt Interstate 35 (I-35) Northeast Expansion (NEX) South Project v San Antoniu v Texasu společnosti Lone Star Constructors. Dálnice v současné době zažívá pravidelné dopravní zdržení pro řidiče.
Toto ocenění následuje po dřívější smlouvě ve výši 606 milionů dolarů na modernizaci úseku I-35 v Austinu v Texasu, kterou provedl dodavatel Pulice Construction. Pulice přidá nový jízdní pruh pro vozidla HOV v obou směrech k I-35 pro úsek mezi státem SH 45 North až US 290 East.
Realizace projektu Interstate 35 Capital Express North by měla trvat pět let, čímž se zlepší dopravní tok a sníží se kongesce. Práce zahrnují nový jízdní pruh pro vozidla s vysokou obsazeností v každém směru podél I-35, stejně jako modernizaci šesti mostů a vylepšení ramp a křižovatek. Kromě toho budou vybudovány stezky pro pěší a cyklisty a také nová bezpečnostní vylepšení.
Re: Texas
Ještě dne 28. července se do provozu odevzdala Route 83 La Joya Relief Route v jižním Texasu. Jedná se o 7,5 míle (12 km) obchvat La Joya v Rio Grande Valley, ale hlavní pruhy se otevřely pouze v polovině cesty k FM 2221.
Na jeho východním konci se pomocná trasa spojuje s Interstate 2. Nicméně nový obchvat, i když je dálnicí, je zřejmě podepsán pouze jako US 83.
Úřad TxDOT, okres Pharr to zveřejnil na Facebooku: https://www.facebook.com/TxDOTPharrTexa ... hzDqEzcLUl
Re: Texas
Společnost Ferrovial dosáhla finančního uzavření projektu rozšíření dálnice v Texasu za 400 milionů dolarů
Ferrovial, globální provozovatel infrastruktury, prostřednictvím konsorcia NTE Mobility Partners vedeného dceřinou společností Cintra, dokončil financování zpoplatněné silnice North Tarrant Express (NTE) v Texasu.
V rámci transakce vydalo konsorcium 414,2 milionů USD pomocí soukromých dluhopisů (PAB). Prostředky jsou určeny především na financování výstavby určitých kapacitních zlepšení požadovaných komplexní dohodou o rozvoji s Texaským ministerstvem dopravy (TxDOT). Vzhledem k úspěchu projektu budou tato zlepšení kapacity realizována dříve, než se původně předpokládalo. Po dokončení této transakce budou práce okamžitě zahájeny s předpokládaným dokončením na začátku roku 2027. Dceřiné společnosti Ferrovial Ferrovial Construction a Webber budou sloužit jako design-build dodavatel.
North Tarrant Express je špičková zpoplatněná silnice integrovaná do sítě řízených jízdních pruhů vyvinuté v regionu DFW během posledního desetiletí; jeho rekonstrukce představovala investici NTE Mobility Partners ve výši 2,5 miliardy dolarů. Projekt, který je plně funkční od roku 2014, téměř zdvojnásobil kapacitu koridoru tím, že zahrnoval řízené jízdní pruhy po celé jeho délce, přičemž celá síť NTE zaznamenala více než půl milionu jízd denně. Projekt pokrývá více než 13 mil (22 kilometrů) podél Interstate Highway 820 a State Highway 121/183 a pomáhá propojit centrum města Fort Worth s mezinárodním letištěm Dallas-Fort Worth.
https://www.prnewswire.com/news-release ... 98939.html
https://www.star-telegram.com/news/loca ... 69757.html
To je docela zajímavá situace. V roce 2009 byla společnosti NTE Mobility Partners udělena koncese na stavbu North Tarrant Express na I-820 a SH121/183 ve Fort Worth a na předměstích. Rozšířila kapacitu přidáním čtyř zpoplatněných pruhů (dva v každém směru).
Pro tento projekt přestavěli celou dálnici, která měla v letech 2010 až 2014 velmi rozsáhlou stavbu. Celková stopa dálnice se dramaticky zvýšila, protože původní dálnice také neměla souvislé přední silnice. Takže i když udělali dálnici třikrát širší, skutečné zvýšení kapacity nebylo tak velké (každý 2 pruhy).
V koncesní smlouvě bylo stanoveno, že kapacita pruhů pro obecné použití (která v té době zůstala na 2 nebo 3 pruhech) se rozšíří o jeden pruh navíc, a to buď do roku 2030, nebo při naplnění kapacity dříve. To poslední je nyní případ.
Na rozdíl od přestavby v letech 2010-2014 bude toto rozšíření provedeno v rámci stávajícího prostoru, většinou s prací přes noc.
Přidají 1 pruh pro všeobecné použití (volný) pro každý směr na I-820 a jeden expresní pruh (zpoplatněný) každý na SH 121/183.
Re: Texas
Práce na kontroverzní 13 km dlouhé modernizaci dálnice I-35 v Austinu v Texasu začnou během roku 2024. Očekává se, že stavební práce budou stát 4,5 miliardy USD. Schválení projektu bylo uděleno Texaským ministerstvem dopravy (TxDOT).
Trasa bude vylepšena mezi Ben White Boulevard a US 290 East.
TxDOT provedl změny v plánech dálnice s řadou zmírňujících prvků, které mají řešit obavy veřejnosti z rozšíření dálnice přes město.
Nyní bude na 15. ulici zvýšený most pro cyklisty a pěší, 100 milionů dolarů bude vynaloženo na vizuální vylepšení, dodatečné financování autobusové dopravy během výstavby, aplikace poskytující informace o stavebních uzávěrách a protihluková bariéra mezi I-35 a komunitními zahradami poblíž Festival Beach.
https://www.kut.org/transportation/2023 ... reen-light
https://my35capex.com/projects/i-35-cap ... s-central/
Re: Texas
V Bastropu v Texasu byla dokončena kvazi modernizace dálnice, kde byly postaveny silniční mosty přes řeku Colorado pro státní dálnici 71 v Bastropu, po které byl stávající most přestavěn tak, aby vyhovoval hlavním pruhům SH 71.
Přibližně 4,5 mil SH 71 přes Bastrop je nyní dálnice s předními silnicemi.
SH 71 je hlavní trasa z Austinu do Houstonu, protože spojuje až I-10 v Columbusu.
https://twitter.com/i/web/status/1704967932256694685
Zpět na „USA“
